주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Verizon용 Samsung Galaxy Tab 4 8.0(SM-T337V)은 Samsung SM-T335라고도 불리며 2014년 4월 1일에 출시되었습니다. 이 8인치 태블릿은 1.2 GHz 쿼드 코어 프로세서로 구동되며, 멀티 윈도우 기능과 300만 화소 카메라를 탑재하고 있습니다.
Digitizer cable issues ugh
I have a Galaxy Tab 4 8 inch from T-Mobile. It works great but recently I have had trouble with the touch screen. I tried a factory reset and the problem still persisted. The touch screen works for the most part but the top 5% of the screen just doesn't respond to touch. I installed a touch screen tester where you draw across the screen and it is definitely the top 5% of the screen below the Samsung logo. I opened the case with a spudger and the screen cable was loose. So I pushed it back down but it doesn't lock in any way. It definitely feels secure but there is no click feeling when you push it down it kind of just sits there. The problem is it comes loose again every day or two. I tried taping it down but it still happens somehow. It also seems like the connector cannot be pushed all the way down because when it is the touch screen acts weird. There will be phantom touches happening when I'm not even touching the screen and parts of the screen work very sporadically. Does anyone have a clue how to fix this. Is there like a foam piece I can buy to keep it pushed down all the time. Or could this be the behavior of the digitizer and going bad? I don't want to have to replace the digitizer because I am horrible at separating the digitizer from the LCD and don't want to have to spend between 50 and $80 on the whole LCD assembly. Has anyone else experienced this specific problem? Any suggestions? Should I just suck it up and try to send it into Samsung? I only got it 3 months ago so it should still be under under warranty I think. Did I void my warranty by opening it? Any help would be appreciated thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
Opening your tablet while it is still under warranty definitely voids the warranty as far as the manufacturer is concerned.
As regards to your cable/connector problem. If the 'locking bar' seems to be not functioning properly, perhaps you could try the following.
Tape down the connector as before and ensure that the touchscreen is working. Then apply small 'dob(s)' of neutral cure silicon sealant (available at hardware stores) between the cable, the connector and the systemboard (or any other suitable point) to hold everything in place. Keep the tape in place to hold it in position while waiting for the silicon to 'cure'. (read the manufacturer's guidelines on the product for how long this takes). Neutral cure silicon is good because it is non conducting and is good for a long time. Once it is set you can remove the tape. Then test that it is still working correctly.
Do not get over enthusiastic with the silicon. Before it sets it is very sticky and messy and hard to remove. It may be easier to apply it with a small applicator (a long matchstick perhaps). Practice first on a piece of scrap material, so that you do a neat job.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Donald Kirchner 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 11
전체 시간: 1,399
