주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Philips 휴대용 DVD 플레이어, 모델 번호 PD9000/37은 2011년에 제조되었습니다.
Volume control not working
Sound is working through the speaker but it's stuck on maximum volume. Turned the volume wheel but volume won't change. Bought used, so I don't have the remote or manual. Is there a way to fix it? Thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
Here is a link to the User Guide for your player.
http://download.p4c.philips.com/files/p/...
If you are trying to use the Volume control on the side of the player (p.13 of the manual) to adjust the sound level and it is not responding, it may be that the control is faulty or perhaps there may be a wiring or component connection problem
Here is a link to the Ifixit guide on how to open the player so as to gain access to the inside of the player and then to the volume control, which should be able to be seen at about Step 3 in the link below, so that you can ascertain what the problem is.
Philips PD9000 37 버튼 교체
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you so much! I will try the suggestions with success hopefully and follow up :)
-Gina
의 공유
댓글 달기
답변을 추가하세요
Gina Aguilar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 10
지난 30일: 39
전체 시간: 6,741
