주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
eMachines ET1831-05는 eMachines에서 생산한 보급형 데스크톱 시스템입니다.
Machine will not turn on
went dead and will not turn on. power supply is good and switch is good. Can not find a mother board for it.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 3개
have you tried a the power supply in another machine or are you thinking its fine because it powers on and you hear it?
의 공유
When i connect my monitor to my computer it pops up and turns black like it turned off.
의 공유
Replace the Hard Drive. Then it will work
의 공유
댓글 달기
답변 4개
선택된 해법
Try this disconnect the power cord and hold down the power button for 60 seconds then plug it back in and see what you get
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
Hello CARL C VANPELT
I only got one solution for this connect the plug to another one at your home to see if the connector is getting power if that didnt work open your desktop and unplug everything wait 60 seconds and plug everything back on to see if your getting any power double check to see if there is no plug missing or damage if that doesnt work you can open your power supply and see if you can find any capacitators damage or other components (WARNING) do not open it if you are inexperience
Hope this help solve your problem :D
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
you wont gain experience unless you boldly go were so many have gone before you
의 공유
Its on but the green power bar is very light
의 공유
댓글 달기
Hey, from your post it sounds like your looking for a motherboard and cannot find one, sounds like u have tested the PSU, and I'm not certain what switch is good, but if u can provide me with the motherboard number I'm sure either I or someone here can find u a mobo for this PC, alternative, I'm not certain that this PC is actually worth getting another mobo for it
http://m.ebay.com/itm/eMachine-ET1831-2G...
Here is a similar PC and is going for 110$, this might be the route you take
http://m.ebay.com/itm/MCP73VT-PM-eMachin...
Here is a mobo I think it might be the right one but I cannot confirm without the mobo number, but see the price for a full one of these is going for around the same price as the mobo itself, but let us know if u need anything else
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Try replacing the motherboard battery. The watch battery looking thing. I did, works great.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
CARL C 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 23
전체 시간: 13,829
