주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
XFX 680 칩셋의 기능을 간소화한 저가형 버전입니다.
RAID 0 gone bad.
any ideas to get a raid 0 array working again? the drives are fine and all the data is on them, but raid doesn't want to recognize them. someone suggested rtools, but a demo version only lets you recover 64kb files. key? other options?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
did I mention this is for an XFX board?
read: running Windows 7.
의 공유
댓글 달기
답변 1개
선택된 해법
If the RAID set is broken, yet you can read the data, your best option is to copy off what you can/need.
The only way I know to get a broken RAID 0 set back working is to set it up as new - which means the existing data is going to be erased.
RAID 0 is all about speed and performance - there is NO data redundancy... Depending on how your RAID controller and RAID 0 set was created, you may only lose files split across the drives (JBOD mode). If your RAID 0 was in Striped mode, you will probably need pay for something like rtools.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
that's what I figured, I'm trying to decide if rtools is worth it because I don't actually remember what's on them. If I knew, I'd be able to decide. Oh you, impasse!
의 공유
의 공유
R-Studio is a great thing. You will certainly be able to use it for other things beside this problem.
의 공유
댓글 달기
답변을 추가하세요
tabormeister 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 22
전체 시간: 4,871
