Why is my grinder overheating?
Recently when i use my grinder, it begins to get very hot after a short period of use. This does not seem normal, could you offer any suggestions to remedy this?
좋은 질문 입니까?
좋은 질문 입니까?
Hey Mackenzie, this is what iFixit suggests you to do if your grinder is overheating:
Grinder getting unusually hot while in use
When the grinder becomes hot and can’t be handled properly.
Use of grinder for long periods of time
While the grinder is in use a certain amount heat will be produced although if the grinder becomes too hot that it unpleasant to handle, you must stop shut off the grinder and allow it to cool off for some time and recheck to see if it has cooled off completely before reuse.
Build up of debris and rust
When an excessive amount of debris and rust build up, it can cause the grinder wheel to be clogged and overheat. In order to solve this issue you can refer to the Accumulation of Debris above section (I copy-pasted the section below).
From use debris can be cause of low resolution when air particles get inside of the grinder. In order to resolve this issue you will have to clean the moving components of the grinder and add a little lubrication oil to keep it moving.
-More troubleshooting fixes can be found here
-Let me know if this helps.
해당 답변은 도움이 되었습니까?
cleaning the grinding so more hot
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 13,726
댓글 5개
student question
mayer 의
some time field coil burn angle grander
wht is the reason
Manzoor Ahmed 의
My grinder burned, what's the reason
Tara Tiwari 의
hello sir i have 9" angle grander . in working time smoke com inside the body . when i open the grander . armachor is burn . why armachor burn what is the reason
Manzoor Ahmed 의
armachor burning reason also carbon brush is crack
Manzoor Ahmed 의
