주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Porter-Cable에서 제조한 PC60TAG는 빠르고 가벼운 연마 작업을 위해 자사의 상업용 앵글 그라인더를 소형화한 모델로, 다루기가 간편합니다.
Why is my grinder overheating?
Recently when i use my grinder, it begins to get very hot after a short period of use. This does not seem normal, could you offer any suggestions to remedy this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 5개
student question
some time field coil burn angle grander
wht is the reason
My grinder burned, what's the reason
hello sir i have 9" angle grander . in working time smoke com inside the body . when i open the grander . armachor is burn . why armachor burn what is the reason
armachor burning reason also carbon brush is crack
댓글 달기
답변 2개
가장 유용한 답변
Hey Mackenzie, this is what iFixit suggests you to do if your grinder is overheating:
Grinder getting unusually hot while in use
When the grinder becomes hot and can’t be handled properly.
Use of grinder for long periods of time
While the grinder is in use a certain amount heat will be produced although if the grinder becomes too hot that it unpleasant to handle, you must stop shut off the grinder and allow it to cool off for some time and recheck to see if it has cooled off completely before reuse.
Build up of debris and rust
When an excessive amount of debris and rust build up, it can cause the grinder wheel to be clogged and overheat. In order to solve this issue you can refer to the Accumulation of Debris above section (I copy-pasted the section below).
From use debris can be cause of low resolution when air particles get inside of the grinder. In order to resolve this issue you will have to clean the moving components of the grinder and add a little lubrication oil to keep it moving.
-More troubleshooting fixes can be found here
-Let me know if this helps.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
cleaning the grinding so more hot
댓글 달기
machine inside cleaning so many more time heat continuances
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mackenzie Fairbanks 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 33
전체 시간: 14,350
