주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic TX-32LX70은 Panasonic에서 출시한 32인치 액정 디스플레이(LCD) 고화질 텔레비전입니다.
Cut (Crop )image up negative down normal
Plz suggest me how to repair my Tv.
Last 2 dy my Tv screen cut image .
Tv up side like negative screen & down side Normal so plzz
what's problem...
My tv num :panasonic tx-32lx70c
Update (06/06/2016)
이미지
See attached file and plzz suggest
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
@mayur could be a panel issue. Just to verify your image appears cropped, upside down and inverted? Post some images of what you see with your question. Use this guide 기존 질문에 이미지 추가하기 for that.
의 공유
@mayur the grey on the bottom of the TV's display or is that just on your picture?
의 공유
That's just on picture,
But top side defect( black sheds ),
See channel name line
Cut he face..
의 공유
댓글 달기
답변 1개
가장 유용한 답변
@mayur unlikely that this would be caused by a bad LCD or a bad driver logic. I would suggest that you start with your settings first. Make sure that you have things like "mirrored" etc. not accidentally turned on. If your menu has a factory reset, try that.
If you are 100% sure that your settings are right and that a reset did not resolve this, you'll have to open up your TV and take a look at the boards. Check for obvious damage and post images of those boards with your question.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
What's Problem My Tv.
Plz Tell Me Details...
I hve open My Television And Clean Dust Also.
Bt No Idea What Can I.
So Plzz Explain Me..
This Problem Faced Last Two Weeks .
Power Shut From Electricity .When
Power Come That Time To Till Date This Problem Faced..
I Don't Understand What's Problem on Television..
의 공유
@mayur Have you done a complete reset yet? Go into your TV's setup menu
의 공유
Which side show reset menu
의 공유
댓글 달기
답변을 추가하세요
mayur 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 27
전체 시간: 748
