주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z5 안드로이드 스마트폰은 2015년 10월에 출시되었습니다. Sony Xperia Z5는 5.2인치 1080 x 1920 픽셀 디스플레이를 특징으로 하며, 퀄컴 스냅드래곤 810 프로세서와 3GB RAM, 23MP 후면 카메라를 탑재하고 있습니다.
z5 Screen stays blank
The led notification light is red, blinks 3 times and then repeats, ONLY when the charging cable is in!
Anyone know how to help? Z5 dual
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 2개
Hold the power and volume down button for 15 seconds and see if that helps. That forces a hard shutdown / reset of the device.
doing the above just resets the LED notification light to the beginning of it's pattern
댓글 달기
답변 3개
가장 유용한 답변
guys my z5 had display but no backlight, I have bypassed the "V" and "A" both fuses still theres no backlight can anyone help?
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
I could sell you a screen, cheap lol.
jbrown05666, I've just bought a brand new screen and its still the same the problem is the motherboard not the screen
My Z5 brightness works only 1/3 at beginning of slider and after that does not go any brighter, testet with 3 different lcd's =(
댓글 달기
In my case, before it start to happens, the colume buttons seems not working very well. Then it worsen where I cant turn off my screen when pressing the power button, but it still detects the fingerprint. Then I press the power button withvintentention to restart but it straight away goes soft reset as if I'm pressing power + vol button. I cant turn onthe phone anymore. The screen will turn on when I plug itbto charger,and it will display battery charging icon. But if I try to turn it on it will vibrate 3 times and it will strqight away turn-off just like soft reset.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
But sooner I find a way to turn it on but only in the safe mode..where the apps acess is limited. Connect your phone to pc. The screen will not turn on bit the notification led will lights up in this manner, red>green>off>red > continuous green. If it happens like that, take it off, plug again. Bit this rime, as soon as the first green lights up,, take out the usb immadiately. Your phone will boot up.
댓글 달기
we found a solution to this! check both the "v" fuse and "l" fuse. if you have picture but no backlight than you have blown the "v" fuse, if you have no picture but have a backlight check the "l" fuse for continuity as you may have blown that fuse
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
where they are?
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 8,272
