주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic TX-32LX70은 Panasonic에서 출시한 32인치 액정 디스플레이(LCD) 고화질 텔레비전입니다.
How To Repair My Television
Plz suggest me how to repair my Tv.
Last 2 dy my Tv screen cut image .
Tv up side like negative screen & down side Normal so plzz
what's problem...
이미지
Update (06/12/2016)
이미지
See up side crop picture
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
post your question in normal english and a little bit more details. And a good picture would help to...
의
What's Problem My Tv.
Plz Tell Me Details...
I hve open My Television And Clean Dust Also.
Bt No Idea What Can I.
So Plzz Explain Me..
This Problem Faced Last Two Weeks .
Power Shut From Electricity .When
Power Come That Time To Till Date This Problem Faced..
I Don't Understand What's Problem on Television..
의
댓글 달기
답변 1개
선택된 해법
@mayur unlikely that this would be caused by a bad LCD or a bad driver logic. I would suggest that you start with your settings first. Make sure that you have things like "mirrored" etc. not accidentally turned on. If your menu has a factory reset, try that.
If you are 100% sure that your settings are right and that a reset did not resolve this, you'll have to open up your TV and take a look at the boards. Check for obvious damage and post images of those boards with your question.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
의
@mayur Have you done a complete reset yet? Go into your TV's setup menu
의
Which side show reset menu
의
댓글 달기
답변을 추가하세요
mayur 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 24
All Time: 416
