주요 콘텐츠로 건너뛰기
This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
Phone will not charge
My phone will not charge. All it does when I plug charger in. Screen stays at 0% (screen shows this) but that's it.. will not charge
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
선택된 해법
Try replacing the battery like the other comment said. At my phone shop that would be one of the first things we would try. Also try a different charger that might be the issue, the charger you are currently using may not be giving out enough power to charge the battery.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
First step would be to replace the battery.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Did that, replaced the grey battery with an aftermarket one off Ebay. It's been 8 months. Now the phone won't charge again. Did the USB cleaning. Changed chargers. Still it gets hot when charging. Won't charge phone says “slow charge” not sure what to do next
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I done everything change battery change charger.its says 0 charging charge before using I put on charging 5 hour same problem showing me again
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
tamrobbins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 13
전체 시간: 3,757
