주요 콘텐츠로 건너뛰기
Repair and troubleshooting information for the ASUS Flip C100P Chromebook. Released in 2012.
Chromebook cannot connect to Wi-Fi
Recently, my Asus Chromebook Flip C100P can not connect to Wi-Fi in my house. I am not sure whether it is a network problem or hardware problem?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 1개
I literally just smacked on my keyboard while it was off. Turned it back on and it worked. 🤣🤣🤣
댓글 달기
답변 5개
선택된 해법
Step 1: Check if Wi-Fi is connected
First of all, you have to turn on your Chromebook. And then, you need to click the status area, and pay attention toWi-Fi icon. If there is a Wi-Fi on sign, it proves your Chromebook is connected to a network and You don’t need to do the next step. If there is a Wi-Fi off icon, it proves your Chromebook cannot connect, and you need to do next step.
Step 2: Turn on Wi-Fi and Pick a network and connect
First of all, turn on your Wi-Fi, Next, you need to click the Wi-Fi off icon and click No network. Then, you need to click Turn Wi-Fi on… or the Enable Wi-Fi icon Wi-Fi signal off, and your Chromebook will automatically look for available networks and show them to you in a list. After you turn on your Wi-Fi, your Chromebook will look for a network to connect to.
Step 3: Check your Wi-Fi signal source
If your Wi-Fi still not connected, you need to check your Wi-Fi signal source. Maybe you need to connect the staffs of network company.
이 답변이 도움이 되었나요?
점수 3
댓글 6개:
I had one that connected to the wifi but didn't work on the internet. I tried a factory reset, and that worked.
Mine says Connect tonetwork..then under that it says to restore data you need an internet connect...how am I supposed to do that when that is the problem..cant connect to the internet.
Mine says I am connected but then does not offer any WIFI connections. All other laptops/phones etc offer several.
Mine keeps losing connection and making me enter the password every 2 mins yet a samung tab right next to it does not?
power washed it two times and it did not work (powerwash is actually factory reset).
댓글 1개 더보기
댓글 달기
가장 유용한 답변
Chaobo, Asus Chromebook Flip C100P can not connect to Wi-Fi in my house, I believe the link below may help you solve connection issue. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.pcworld.com/article/2365771/h...
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Anyone know what I can do? I’ve only had this laptop for 6weeks and this is happening until last night it won’t find any wi-fi networks.
Ive done a washout if that’s what it’s called and still get the same thing.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
this is happening to me, i rang support and they weren't helpful at all. Needed to pay 50 pound even though I haven't done anything to it. Did you figure out a wayto fix it? :-(
Same exact problem I'm having. It's a school district chromebook for my son and worked fine yesterday thrn all of a sudden I couldn't login bc ut was not connected to wifi and when I tried to turn it on it didnt show the scan list of available networks and the only option it gave me was to manually input and set up a VPN (no clue on that). Help!!!
Also, then I shut it down m restarted and i had the same exact issue on my screen as Rebecca Ogden where it now only allowed manual unlit of a network, but now I could input a WPA, EAS I think it was and a WEP....I know my wifi has wpa printed on it so I tried to manually input it and got the same error. Network error no connection. So I'm at a loss please help my sons missing so much virtual school over this...
댓글 달기
Set Certificate to default
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Where how only has security option, network name and password spaces to input
댓글 달기
Power off your Chromebook (I did a powerwash of my Chromebook before shutting it down) and Router. I have EERO Pro mesh for my router/network. I disconnected the power wire and ethernet cable from my main EERO router, waited a minute, then plugged them back in. I waited until all my EERO mesh points were back to the white light. Then, I turned my Chromebook on, found my network, input the password, and connected immediately and was able to set up my Chromebook.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chaobo Dong 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 70,663
