Chromebook keyboard not working
The keyboard on my couple month old Chromebook is failing. There are some keys were not function. By the way, I am out of warranty. Please tell me hoe to fix this problem.
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
Character keys on the right side of the keyboard do not work. For instance;
On the number row keys 9, 0, -, = do not work.
On the QWERTY row keys o, p, [ do not work.
On the ASDF row keys l, ;, ' do not work
On the ZXCV row keys the period key, and backslash key do not work
Character keys on the left side of the keyboard work OK
Modifier keys like esc, enter, shift, ctrl, alt work fine. Same for page left, right, up, down keys.
Top row function keys are all OK
This Chromebook has been Powerwashed as per Google support. Keys noted above are still dead.
Next step will be to open the case and look inside.
이 답변이 도움이 되었나요?
My keys q e r t a d f g z c vb won’t work and I’m stress out bcs i rlly need to go on it
Similar problem on mine - the following keys were either sticky or not functioning:
0 - = ] # ' / n b and the 'previous page' key on the top row.
I opened up the Chromebook, took out the keyboard (careful with the two ribbon connectors) and spotted that there were crumbs and dust inside. I wondered if these might have come through the keyboard, so using a compressed air can, blew air through the keyboard from all angles, giving it a really good shake and clean.
Having gently blown away any crud from the interior of the Chromebook, I reassembled the thing and found no more sticky/non-functioning keys.
Message to self: easy on the biscuits...
이 답변이 도움이 되었나요?
i have had this problem many times. I usually just keep rebooting until itworks. Connect a bluetooth keyboard and keep rebooting. Mine usually fix after a week or two.
이 답변이 도움이 되었나요?
I browsed as guest because I couldn't login. Then I hit the microphone icon and spoke my question and google help said to do a hard rest. Said to shut down the Chromebook. Then hold down on the refresh button and the power button at the same time. Then when the Chromebook started up release the refresh button. I did this but it didn't come on. So I released both buttons. Then powered it on and the keys were back working. Yay.
이 답변이 도움이 되었나요?
Right. A hard reset is a prescribed fix for troublesome Chromebook keyboards.
Here’s a link https://support.google.com/chromebook/an...
I wasn’t aware of this until I sent my relatively new Asus Chromebook to the Asus service center for repair. My Chromebook came back, fixed by this user level procedure.
이 답변이 도움이 되었나요?
이 답변이 도움이 되었나요?
I have an ASUS Chromebook C100P and I bought 2 keyboards. Each keyboard I bought always went out after a couple of months. Fortunately, I found out that it was just a loose connection. In order to fix that, you must open up the computer and make sure the two strips are secured. If I had known that, I wouldn't have gone through 2 keyboards. Save your money and make sure the connection is secured!
Completely agree with Kara, I replaced my keyboard as it had issues described as above, keyboard worked for a few days then stopped working again...I then secured the ribbon cables and all working again..
I had the same issue but with various other keys, some i ordered and replacement keyboard, installed it...once the installation was complete it worked like an charm but at few hours later when i switched it in keys stopped working again ... In between that there was any update so is it an update thats causing this problems????
이 답변이 도움이 되었나요?
me spelling is shi cause i cannae use cerain kehs on me kehboard cause if i use hem deh of meh google chromebook. plz help i h8 spelling dis badlleh. basicalleh when i use deh ledr before z and da ledeh before u and a few oders da chromebook swiches off
이 답변이 도움이 되었나요?
I had similar issues. Reseating the ribbon attaching the keyboard to the motherboard fixed my issue - although I had to do it several times putting firm pressure on the connection clip.
이 답변이 도움이 되었나요?
I am also facing the same problem while trying to connect my AirPods. Then I read ***https://www.genderlessvoice.com/how-to-c... and it works for me.
이 답변이 도움이 되었나요?
지난 24시간: 4
지난 7일: 8
지난 30일: 15
전체 시간: 23,305
댓글 1개
When I press the t and y keys nothing happens. When I press the g and h keys they type t and y when I press b and n keys same thing as the t and y keys. Please Help!!!
Thomas Kabel 의
