주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple iMac M5521은 1999년 10월부터 2001년 여름 사이에 생산된 슬롯 로딩 방식의 iMac G3 올인원 데스크톱 컴퓨터입니다.
Putting an LCD inside this?
Hello,
I just tore apart my iMac G3. The case is in excellent condition. I want to get a MacBook or iBook logic board and put it in the case, along with a LCD. But, I don't know where to get a monitor that's 14.5 diagonal, 11.5 across, and 8 7/8 inches in height. Does anyone know where to get a monitor like this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Never mind, I just found a monitor that will work. Might have to stretch the picture a little bit though.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I'm using a E173FP, it fits perfectly.
의
댓글 달기
가장 유용한 답변
@gigabit87898 you will have a very difficult time to find a LCD that will be compatible with a "MacBook or iBook logic board". You will have to modify the case a lot because of the shape of the original board. I'd abandon the idea with those boards pretty quick I'd suggest a build like this or this one. Remember that you will have to modify the front bezel as well due to the curvature it has for the CRT. Your will have to come up with a way to create a straight window. I am currently working on a Hackintosh from a MacIntosh Classic II. So take lots of pictures and create a guide which you should then post on here.. Let's compare notes when done:-)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Gigabit87898 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 42
전체 시간: 1,923
