주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Aspire V5-571-6891 노트북은 개인 또는 소규모 비즈니스용으로 2012년에 출시되었습니다. 본체는 대부분 검은색이며 중앙에 은색 로고가 있습니다.
laptop work but blank screen
when i try to boot it up it starts but the screen stays blank what are the possible solutions??
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
Can you see any mouse or anything on the screen ?
It might be very dull so you might have to really look for it.
의
Hi,
Does the screen 'light up' or stay black? If it stays 'black' try shining a torch at an angle close to the screen and see if you can see the desktop display once it has booted up. If so it could be a backlighting problem.
Try connecting an external monitor and see if there is a display on it when you boot up.
의
댓글 달기
답변 3개
선택된 해법
@tetzel , johann, Try hooking up an external monitor, if external monitor works probable laptop display issue, corrupt driver, bad connection on ribbon cable, bad display. If external monitor not working could be graphics card issue. Below link tells how to hook up external monitor to help trouble shoot your laptop, the 3rd link and other Acer forums on the net, addressing Blank/black screen talk about the Bios becomes corrupt and needing addressed. Good luck.
http://www.yumapk.com/how-to-connect-ace...
http://community.acer.com/t5/Legacy-Lapt...
http://www.tomsguide.com/answers/id-2221...
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Take out the battery. Press power button for a minute. Then put battery back in again and power up. Repeat couple of times if necessary.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Possible that your memory needs to be re-seated
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
johann bayzil 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 24
전체 시간: 10,611
