주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 700m은 Dell에서 설계한 초경량 노트북입니다. 12.1인치 와이드스크린 디스플레이와 가벼운 디자인으로 유명하며, 이동성과 일반적인 생산성 작업에 적합합니다. 저자: Phillip Nguyen
Can I upgrade this old computer
I have a Dell Inspiron 700 m with Windows XP which is running well. However, as Windows XP is no longer supported I am afraid to connect it to the internet. Is there anyway to upgrade this computer so I can run a more current version of Windows which would allow me to add anti virus software to safely connect to the intranet? Thank you in advance.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Thank you for the advice . I will check out the sites you recommended
의
You can improve the 700m by using a dual band network card, The 2915abg is a
dual band NIC with a PCI plug and works good. it was used on an earlier model
and I dont why this NIC was never mentioned. I am intending to ask MKafee if
they have a package for windows xp to guard against problems while on the web.
의
댓글 달기
답변 3개
선택된 해법
@terrymcd biggest issue here will be the display driver. dell does not provide any approved ones for your model. There are work arounds so you could in thoery update to Win 7 at least. However you can upgrade your memory to max it out and also optimize your hard drive. Just because there is no longer support for Win XP does not mean you have to stop using it. You can get lots of anti virus for Win XP so you can safely connect online. Places like this and this one are a good start checking things out.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I would put linux on it, viruses won't be a problem, and it will run fast on old hardware.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
you can add linux to your machine (but be aware: modern linux can have issues with your machine (I tried ubuntu, fedora and I got a lot of issues)
I decided to use open suse 12 (which works great)
note also that when installing the celeron chip do not display the PAE bit, so you must append this to the installer: forcepae
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Terry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 1,746
