주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for Lenovo's 3rd-gen ThinkPad X1 Carbon laptops.
9 질문 전체 보기
Lenovo Thinkpad X1 Carbon Gen 3 LVDS fuse blown? Display blank
Replacing cracked screen on 3rd generation Thinkpad X1 Carbon. Cust used for a while with cracked screen and then it went black after a few days. Installed new screen, still black. No image at all. System still works fine when external monitor is connected however checking in device manager built in screen is not detected at all so it's not just backlight. Thinking maybe a blown fuse or issue with LED driver? Can't find schematics for this motherboard.
Update (09/12/2016)
Motherboard part numer 448.01406.0011. Lenovo FRU 00HT361.
Pics of LVDS connector and bottom side of motherboard underneath LVDS
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
For me it was fuse f3. After creating a short cut it works. Really important to unplug the power while changing displays.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Hello @lucek4, may you suggest the f3 fuse location. Thx you
댓글 달기
Good Day!
I have exact same problem after replacing cracked screen, I have x1 gen 2, almost the same smd fuses, for me the fuse F7 was blown i replaced it but still black screen and the fuse is blown again right after replacement, Can you read the number on that 8pin IC next to the fuse something like F28 or something, i need to replace it but couldn't find the part number as i can not read it, I think it is the power regulator or driver for back light. i checked all surrounding parts like diodes and capacitors all good only the fuse is blown which is connected direct to this IC, so i think it is short or blown, i see picture with torch on screen but no backlight,
thanks
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks Khizar for this post,
I would appreciate if you add a picture to both areas of the F7 and Pin8
I could not locate them.
댓글 달기
Thanks for your feedback. I have made a seperate thread. Here is the link.. you can find fotos there.
No backlight with blown fuse under lvds connector
Thanks for your help.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
managerharry 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 20
전체 시간: 4,350
