No reverse on my golf cart
My electric golf cart lost its reverse can I fix it myself or do I have to take it in to a service center?
좋은 질문입니까?
좋은 질문입니까?
@gerryr, this could be as simple as the reverse switch being the problem. It is a mechanical contact and could be not making the connection. You can check that by switching the wires from the forward/reverse switch and see if you now have only reverse. If so, you know it's the switch. You did not tell us if your cart has a backup beeper and if it still comes on. Also, let us know if this cart has a dash mounted toggle switch.
이 답변이 도움이 되었나요?
2008 yamaha cart with back up buzzer
what if its not the switch?
I replaced the forward reverse control board. Now I have no reverse. Reverse worked prior to replacing control board.
@mikegolf have you tried to switch the wires to see if you then have reverse but no forward?
Hi my ez-go 2005 txt cart suddenly decided to not go in reverse ! the reverse alarm sounds but the cart won't go ! it will run forward when I push on the rocker switch. I checked the contacts behind the switch and they are ok no broken or frayed wires.
mine was the micro switch on the passenger side of the forward reverse switch. I just bent the prong put on the lower side of the metal just below the white tip of the switch. This way it pushes further into the switch housing.
이 답변이 도움이 되었나요?
I have a 1998 club car and it was going in reverse with the reverse beeping noise and NOW it not going in reverse are forward
Series ds ? 48v ?
If you have a CC DS Series setup (2000) and you loose reverse but have forward check your FNR switch it’s the 3rd micro switch lever (closest to you) bend it up to make full contact and it will work perfectly. My cart is completely modified 48v lithium battery and plum quick motor (vigilante) upgraded Curtis 1205 controller 325a and stock aftermarket solenoid. Had nothing but issues the last two weeks and finally overhauled the wiring (4 gauge welding wire) and connector's (waterproof connectors) today and figured out why post 2-3 only work if there together for reverse and that is cause the tab on the FNR is not bent enough to make contact. If you plan on making big changes to the electric upgrade the wire right away don’t wait my old wire caught fire and burnt the FNR. Test drive completed and clocked 33mph. 6in lift on 24s single battery. If you need any help look up 48v club car ds wire diagram and look for model diagram. , it helped a lot tracing the wires out ! Don’t go to the shop find it n fix it !
My motor and controller (stock 25 years old) both & the solenoid all burnt out at the same time and left me suck.. I had to walk home and get my quad to come tow home the cart. That’s what happened when my forward gave out but my FNR was also fired from an electrical fire I had.
@mariejohns70703 still having issues
지난 24시간: 8
지난 7일: 46
지난 30일: 253
전체 시간: 66,870
댓글 10개
Would you give us your model number?
mayer 의
EZGO textron serial number 833198
gerry 의
@gerryr and the make of your cart as well :-)
oldturkey03 의
I find nothing but EZ-GO on the cart
gerry 의
Okay lets get to work. Based on your serial number you have a :
Make: Medalist
Type: Electric 36 V
Model: Electric Medalist
Year: 1994
Sounds about right?
oldturkey03 의
댓글 5개 더보기
