주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년 4월 1일에 출시된 Logitech 사의 유니버설 리모콘입니다. 이 리모콘을 사용하면 MyHarmony 애플리케이션을 통해 가정 내 엔터테인먼트 기기용 리모콘을 최대 4개까지 하나로 통합할 수 있습니다. Harmony 300 모델은 무광 검정 마감 버전이며, 300i는 유광 검정 마감 버전입니다.
Why dos not work OK button
Why does not the "OK" button.
mechanical connection to the contact site is good.
By pressing the OK button is not lit LED and IR do not send
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
You say that the mechanical connection is OK but possibly the electrical connection is not. Most remote controls buttons have a conductive surface on the underside that when you push the button, bridges across the contact strips on the circuit board completing the circuit.
Sometimes the problem can be fixed by opening the remote control and cleaning the contact strips using Isopropyl Alcohol 90%+. The underside of the buttons can also be cleaned using the same method.
However it may be that the conductive surface on the underside of the button has been worn away through use. Usually on most remotes the power button and the OK button fail first due to the fact that they get the most use.
If it has been worn off then you can try applying a thin coat of what is known as conductive glue (or paint) to the underside of the button. Look for it online, Ebay etc, I have had mixed results using this method, initially it works but it doesn't last very long.
Here is a link to a video that shows how to clean your remote. The video is not of your particular remote, it is just to show you the principle.
https://www.youtube.com/watch?v=yWpMcXWl...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
aarvasevicius 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 32
전체 시간: 2,266
