주요 콘텐츠로 건너뛰기
Released in December 2011, identified by model number LT2016U. Repair requires screwdrivers and pry tools. Black / 10.1" Display / 1.6 GHz Intel Atom Processor
netbook FAN smells like DETERGENT
Hi there can I ask i just brought a 3g motherboard of gateway LT2016U at Ebay and i just wonder if this motherboard has a problem, just notice its smells like a detergent. on his cooler fan.
no problem with performance it runs smooths and stable fast. and operates in normal temp...
is this something wrong with this?
please help me thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I personally don't like the sound of a motherboard that smells like it's been cleaned with chemicals. It may however, just have sat for a long time in someone's home who uses a strong laundry detergent that lingers in the air. It would make sense that the dust particles in the fan particularly have a strong scent.
The only thing I would use on electronics is denatured alcohol, which evaporates quickly and shouldn't leave a smell. If the smell is more like an abrasive chemical cleaner and strong across the entire board, I personally would return it. Even small amounts of liquid can cause corrosion that manifests problems later down the road.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks for that info Patrick i am agree what you have said . well i will chat the seller of this motherboard.. so i can ask for refund. the reasons why i brought this because i want a built in 3G on my netbook and its hard to find a 3g motherboard here on ebay at cheap price.. well i will observe this and try to use it continuously to test if will cause a problem soon.
댓글 달기
답변을 추가하세요
Nic Norman Tugaff 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 123
