주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
G71t-300은 2009년 8월 HP에서 출시한 노트북입니다. 통합 웹캠, 그래픽 카드, Windows 7 운영 체제를 탑재한 범용 소비자 기기입니다.
How to fix Wifi problems?
My HP G71t-300 does not detect my home Wifi. I have tried turning the device on and off already, as well as resetting my router.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 5개
가장 유용한 답변
Maybe your wireless drivers are out of date. You might consider plugging into ethernet temporarily and updating those drivers to see if it resolves the issue.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Check if you can connect to your home network with a 2nd laptop. If you can, then the 1st laptop has something wrong with either the wifi module itself, or the drivers for the wifi module is not installed/the wrong one. For replacing the module, see this guide. For installing the drivers, download them from the HP website using another computer, and transfer it to the 1st laptop via an external storage device.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If your laptop can detect other Wifi signals but not yours, then this is most likely an issue with your internet provider or modem and not with your laptop.
If none can be detected, however, you may need to replace the Wifi card in the device. Refer to this pagefor further information.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If your laptop detects other networks, then it may be an issue with your internet provider or your router/modem. Contact your ISP for further assistance.
If no networks can be detected, you may need to replace your wifi module.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If your laptop doesn't detect any wifi networks, the laptop's wifi connectivity may have been disabled. Check that the switch for the wifi card is on or find the key to turn on wifi.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jake Dykeman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 17
전체 시간: 526
