주요 콘텐츠로 건너뛰기
The fourth generation Volkswagen Jetta, also called the MK4 or the Bora, is Volkswagen's family sedan.
Starter relay location under dash
1999 Volkswagen Jetta, got a starter relay, took out the panel below the dash but, can't figure out where it goes.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 7개
Still can't find the location. The numbers don't match and neither do the prongs.
Add more info. what is it doing, engine size, gas or diesel, standard or automatic,
is it 1995.5 the newer style body MK4 or the old style boxier type body 1999.
Doesn't start. Everything comes on but it don't turn over. No clicking, no noise. Automatic transmission, box type, 2.0 engine.
@deviousdawny , is the security light on, your problem also could be safety neutral switch, ignition switch faulty, did you find and replace the relay, etc.
Turn ignition to on position and shift to neutral and try and start and then slam the gear shift back to park and try to start, If this works the safety neutral switch needs adjusted or replaced. It may be time to have a good technician to have a look, diagnose and estimate repair. Good luck.
@deviousdawny , I also got thinking about the relay you purchased and was thinking perhaps the parts store could of errored and gave you the wrong part.
http://faculty.ccp.edu/faculty/dreed/Cam...
happens a lot.
댓글 2개 더보기
댓글 달기
답변 3개
선택된 해법
Dawn, 1999 Jetta neutral position switch or the starter interlock relay is up under the dashboard on a panel full of relays, may have to remove the lower dash trim. Should see it through the gap between the fuse panel and the dashboard.
Jetta equipped with manual transmission, the relay position is third from the left on the upper row and auto transmission equipped, the relay is third from the right on the bottom row. Good luck.
이 답변이 도움이 되었나요?
점수 6
댓글 2개:
Appreciate the help.
I've replaced the ignition relay under dash,but still no noise when I turn the key,what else can I check?
댓글 달기
I'm not finding the correct relay. The numbers are different and the prongs are different.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Dawn I realize that you asked answered your own question. But you picked a poor answer (your own) as a solution. If you don't get the answer you need, it is best not to accept an answer as people then stop looking at the question. Try unaccepting this answer and clarifying your question to get something that actually fixes the issue.
댓글 달기
Were you able to figure out the problem and if so hiw did you correct it im having same issue with my 06 jetta
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dawn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 25
지난 30일: 114
전체 시간: 41,760
