주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 기기 페이지는 사용자가 Canon PowerShot SX260 HS의 다양한 부품을 교체하는 방법을 안내합니다. 여기에는 대체 스크린, 마더보드, 배터리, 셔터 버튼 교체가 포함됩니다.
Yanked off the Mode connector... now what?
So I was trying to reset the display connectors because I had the common problem of LCD screen going dark. But when I removed the back case panel, and had to remove the connector for the mode settings, which is attached to get the entire back cover off, instead of just sliding it up and out, I yanked off the entire housing. Is it ruined now? There seems to be no way to just pop it back into place.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
I do not know if you were using it but here is a link to the Ifixit repair guide(s) for your camera. Hopefully there will be some information contained in the various guides that will help you.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Yes, I looked at those guides, but those are all "normal" repairs, like replacing lenses, screens, etc. My question is something I did out of the ordinary. Instead of pulling out a connector, I yanked off the entire housing for it. So if there is an expert out there on Canon cameras, my question is should I spend my time taking it into a repair shop, or is this toast now? (To be more specific, basically, I yanked out the entire white connector housing for the connector that attaches to the mode selector wheel. So now, I can't select a new mode at all - portrait, tv, live, p, av, m, etc. The connection to that is gone.) Is this a smoldering job, or is it not even worth trying?
의
댓글 달기
답변을 추가하세요
Peter Oh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 11
전체 시간: 249
