주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon D80은 2005년에 출시된 1,020만 화소의 디지털 일안 반사식 카메라입니다. 사진 촬영 및 영상 녹화용으로 설계되었습니다.
SD card slot problem
SD Card will not click into position, it bounces back out, I can shut the door and make it go in, then the review gives me the message there is no card.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hi, Have you tried a different SD card to see whether the problem is with the card or the camera?
의
댓글 달기
답변 3개
가장 유용한 답변
I had this issue, did some research and found out that a tiny sliver of one of my SD cards could have broken off into the chamber. I got a flashlight and WA LA.... yes, that is what happened. I watched a video of a guy who dug his out himself. I did not have such luck, and am taking my camera into a professional who will charge me 30 bucks to get it out. So, get a light and look!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
You know the card has to be pushed against the spring until it "clicks"?
Might be that the mechanism which holds the card in is broken and hence the card bounces out.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had the same problem with my D80. I sprayed some compressed air into my SD card slot and it started holding on to the card again. Got lucky. My guess is there was some debris present that prevented the SD card retention mechanism from engaging.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
photokellytaylor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 32
전체 시간: 1,468
