주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Minolta QTsi Maxxum은 자동 카메라입니다. 5가지 사전 설정 노출 모드, 탈착식 35-80mm 줌 렌즈, 4가지 모드의 자동 팝업 플래시 등 몇 가지 특별한 기능을 갖추고 있습니다. 기기 모델 번호는 312875입니다.
Why does my camera randomly shut down?
Sometimes my camera will shut down when I am taking photos and I don't know why. Any thoughts?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
선택된 해법
Sometimes your camera may shut down due to a malfunctioning power supply.
Remove the batteries from your camera for 30 seconds, put them back, and then see if that solves your problem. If the issue continues, try replacing the batteries all together.
If your camera still turns off frequently, it might be suffering from an overheating problem. That can progress into further issues, so you should check out the overheating section of this troubleshooting page. It also address different problems that may occur with your specific camera.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
@jordanellery , Jordan, Minolta QTsi Maxxum shuts down when I am taking photos, try different battery, ensure batteries are healthy and charged check in your cameras settings or if timer is set, to see if camera is in power save mode. Link below is a manual for your camera. Good luck.
http://www.tashimareport.info/Minolta/si...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I have a X-300 and im having a similar problem where I get lights indicating the battery being exhausted despite the batteries being fresh and new. I looked it up and im pretty sure it's from a faulty capacitor. You might have the same problem, the good news is theres a way to fix it, the bad news is you need to have a screwdriver, and a soder gun, If you do you can follow this tutorial https://www.google.com/url?sa=t&rct=j&q=... If you don't you might be able to send it somewhere to get fixed.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Jordan Ellery 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 46
전체 시간: 4,315
