Why is my controller moving the character when I am not
My controller causes my character to move when I do not move the control stick. Is it dirty or is it just a bad signal?
좋은 질문 입니까?
좋은 질문 입니까?
Often times, disconnecting the controller and blowing into the connection port on both the controller and console can fix this problem.
해당 답변은 도움이 되었습니까?
Turns out there was an error when the console recognized the controller so I just unplugged it and re-connected it to the console
해당 답변은 도움이 되었습니까?
It may be dirty or your joystick may be misaligned. I recommend you check out our joystick replacement guide, and use the steps to clean out the area and then reattach your joystick. If the problem still persists it may be a problem with your motherboard.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 361
댓글 1개
Turns out there was an error when the console recognized the controller so I just unplugged it and re-connected it to the console.
Andrew Gonsalves 의
