주요 콘텐츠로 건너뛰기
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 질문 전체 보기
Why is my Nissan Altima 2.5s smoking
After changing the spark plugs and replacing new engine oil I found out that my car has been smoking profusely since then what could be the cause and the solution. Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
if you have not changed the oil in a very long time causing a build up of dirt on the rings and causing them to wear . When you put new oil in this cleaned the rings and now with the wear its letting oil pass the rings and this causes the smoke. Or you could have used the wrong oil . Make sure you used the proper weight oil .
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
amossy2003 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 2,376
