주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei Ascend Y600 안드로이드 스마트폰은 480x854 디스플레이와 1.3 GHz 프로세서를 탑재하고 있습니다. 2014년 6월에 출시되었습니다.
Huawei y600 got wet
What is the solution when mobile phones got wet?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Do not try to power on and remove battery asap. then follow Jimfixer answer.
댓글 달기
답변 1개
선택된 해법
Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best. This may be helpful . Hope this helps
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
arnoldgriarte 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 19
전체 시간: 639
