주요 콘텐츠로 건너뛰기
Released in July 2008 by Acer Inc., this netbook can be identified in the ZG5 Acer Inspire One family with the model number A150-1672.
3 질문 전체 보기
My computer is frozen and unresponsive.
Randomly my computer froze and the mouse won't move on screen. I can't pull up the task manager or get anything to happen. When I press the power button, it will go to a black screen, but when I hit it again, it comes back to the same frozen screen.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
student question
My CP is stuck frozen how do I get it unfrozen
댓글 달기
답변 4개
선택된 해법
The computer may be taking in too much input or there could be a malfunctioning program or application.
Since you can't restart the computer on-screen, the best way to fix this is to do a hard reset by either holding down the power button until the computer totally shuts off, or by removing the battery.
After this, it may also be good to do a system restore to a time before your computer froze to make sure that there weren't any changes to your computer that caused the freeze.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My pc doesnt work when i turn it on my mouse doesnt move on screen restart it and the pc is still frozen please whoever fixes this I need help.
Thank You
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
What if its a new one without a battery?
댓글 달기
Remove the battery if you can, and if the device has a CMOS battery, remove that for 10 seconds. Replace both.
If you still get the same results, you may want to try replacing the hard drive, as I see this as a plausible reason for these symptoms.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
How do I for sure get it unstuck
This is a new CP how can the hard drive be bad
댓글 달기
Control + Alt + Delete and restart.
I’ve had this problem a couple of times, but this always fixes it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Connor Watkins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 38
지난 30일: 223
전체 시간: 26,650
