My Phone got wet, it turns on, then keeps shutting down. Help
I dropped my phone in water and I put it in rice for a couple days. It turns on but then shuts down after a few seconds
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Rice is good to eat but does nothing to fix the problems caused by corrosion
Don't Put Your Device in Rice. Here's Why...
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
You may have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
If this process seems too daunting, take your phone to a reputable, professional phone repair service and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
해당 답변은 도움이 되었습니까?
@jayeff I like the link to "Don't put your phone in rice" , I'm gonna have to use that . Excellent answer BTW
Hi @jimfixer
Thanks. If you go to use the link if you do it like I do i.e. copy and paste the URL it doesn't work, it sends you to the incorrect page, it shows up as a red link. You need to put the URL in square brackets [... ] to make it work. Then it shows up as a blue link and it gets you there. I've informed the Ifixit crew a while ago guess they're still working on it
good to know
What if the cover to the battery doesn't come off?
Firstly,
Stop turning it on. That is how the water will do the most damage. If you can remove the back and the battery and let it air and dry out.
How wet did it get?
해당 답변은 도움이 되었습니까?
Bro my phone has enter the water from bottom left side and I saw in display the water and display get on off on gf automatically and get automatically shut down and after that I'm dry it on rice for one day but it can't start what can I do
My phone is Motorola Moto one power
Hello.
My S10 phone drop in bucket of water and went off.
I picked it with-in 10 seconds.
Trying to on or even charge but can't.
What is the best solution.
24 시간 전: 20
7일 전: 137
30일 전: 606
전체 시간: 48,184
