주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AKASO KingPad A90은 듀얼 코어 프로세서를 탑재한 9인치 태블릿입니다. 8GB의 내장 저장 공간을 갖추고 있으며, Google Android 4.2 Jelly Bean 운영 체제를 실행합니다. 전면 카메라와 후면 카메라, 후면 스피커를 갖추고 있으며 HDMI 출력을 지원합니다. 이 기기는 2013년 10월 31일에 출시되었습니다.
How can I replace the headphone jack?
Headphone jack not working on KingPad tablet. Jack is not clogged.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
you can fix it by going to an tablet shop
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
hey guys this is my first time doing this and the reason i am doing this is because i love helping others
의
@azellya ,
That's fine but first try helping by providing an answer that allows the OP to try and fix the problem themselves.
After all that is the name of this forum I - FIX - IT (ifixit)
e.g. if you click on the device icon at the top right of this page, you will find links to the ifixit repair guides for the tablet.
You could suggest that they use the guides to open the tablet so that the headphone socket can be inspected. maybe it is just loose from the systemboard and can be resoldered back on or if it appears to be OK perhaps you may be able to find a compatible replacement headphone socket supplier online etc. that you could link into the answer.
Advising the OP to contact a professional repairer is OK but not in the first instance. Most people would already know to do this anyway and wouldn't come to this forum just to hear what they already know .
View how others answer questions on this forum, especially those with a high reputation count (look under the avatar for the Rep points) to get an idea of what may be required in an answer.
Your motives are good keep it up.
Cheers
의
댓글 달기
답변을 추가하세요
lgadzinski 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 442
