주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Split x2는 2013년 중반에 출시된 13인치 하이브리드 태블릿/노트북입니다. HP Split은 분리형 디자인으로 쉽게 식별할 수 있습니다.
How do I fix my split x2 touchscreen
I mistakingly dropped my split x2 and the touchscreen got a crack, the screen still display fine but the touchscreen is not working. I can only use it with the dock and not as a tablet again. Pls where can I buy the touchscreen and how do I fix it
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
You may be out of luck.
Here is a link to the service manual for your laptop. Hopefully I have got the correct one.
http://www.hp.com/ctg/Manual/c03958968.p...
It shows that the touchscreen is part of the display panel and not a separate item. Scroll to p.17 &19 to view parts and part numbers. It also shows that the touchscreen board (not the 'screen') is not available as a spare part so hopefully it is OK (part #9 on p.17)
If you search online using just the part number of the display you will get results for suppliers of the part.
Below are just some examples, you might find others that suit you better. They are only shown to give you an idea of the cost depending on what type of display you have.
This is for a WVA display.
http://www.ebay.com/itm/LAPTOP-LCD-LED-S...
This is for a UWVA display
http://www.ebay.com/itm/HP-Split-X2-P-N-....
The service manual shows the necessary pre requisites and procedures for replacing the screen.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Kayode 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 16
전체 시간: 1,041
