주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6세대 Honda Civic은 1995년에 처음 출시되었습니다. 4세대 및 5세대와 마찬가지로 Honda의 레이싱 연구에서 영감을 얻은 첨단 독립식 서스펜션인 전륜 더블 위시본 서스펜션을 탑재하여 동급 최고의 핸들링을 유지했습니다.
Car turns off while driving.
My car won't stay on while I'm driving. Sometimes the car won't turn on at all. I have bought new plugs, cap and rotor, and alternator, still no luck. Please help!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
Hi, Take the vehicle to an AutoZone store (if in the USA - they do it for free apparently) and get the OBDII port scanned to see if there are any fault codes there which may give you an indication of what the problem is.
의 공유
댓글 달기
답변 3개
가장 유용한 답변
Anecdote:
My civic died while driving.. wouldn't start.. after it cooled down a bit, it turned right back over... only to die again after idling for a minute..
turned out replacing the distributor fixed it... i landed on that after a lot of googling... people said the igniter inside the distributor is likely bad, and when it heats up it fails.
I see you posted this in january, so....
이 답변이 도움이 되었나요?
점수 2
댓글 달기
My honda civic stalled while driving it started back up I went on it stalled again 6times till I got home cooled down last 2 days ran fine help
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have been having problems with starter going to replace tied tapping starter may have very lightly touched distributer don't thing I damaged it definitly didn't crack it could this have caused my problem
의 공유
댓글 달기
Have you checked the battery? If so then check your starter fuse.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jhou'quan Glenn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 33
전체 시간: 2,705
