주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Chromebook C710-2847은 Google의 운영 체제(OS)인 Chrome OS를 실행하는 Acer의 저가형 넷북 제품군 중 하나입니다. 이 기기는 구조가 단순하여 분해 시 스크루드라이버 하나만 있으면 됩니다.
Is there a Screen switch?
Recently started having problems with the screen turning on/off intermittently. Opening the screen sometimes it goes blank, fades or screen is all grey. Noticed that if I grab the right corner near the hinge and squeeze upper and lower halves together it comes on. Also noticed the screw at that corner holding the halves together is stripped. Is there a switch in there that activates the screen when opened. I cannot remove the stripped screw. It is stripped in place and will not come out. Any help would be appreciated. Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I believe you would have to replace the LCD, I've had this issue in the past and I believe that's what I did. There should not be an "LCD Switch" and as for the stripped screw, I would try using a flat heat. I use two methods of removal of stripped screws. I either solder something into the screw and then remove it or I Dremel a pattern and unscrew it with a flat head.
I'm not sure if this helps but good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dennis Damico 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 17
전체 시간: 400
