주요 콘텐츠로 건너뛰기
모델 A1237 또는 A1304 / 1.6, 1.8, 1.86, 또는 2.13 GHz Core 2 Duo 프로세서
312 질문 전체 보기
Hard drive connector interface for A1304!?
After looking very closely at the pictures in your article it seems that the A1304 actually has a Samsung Sata 1.8" drive in it!! What is the largest replacement drive for a 1.6GHz A1304 Macbook Air ? Does this drive need a micro-Sata interface?
I had been led to search for a 1.8" Pata Zif 5mm drive because there is a comment in your article about there being "no Sata" connection on the Motherboard and then a reference to Pata/Zif. But there is NO clear indication in the article what the actual interface/plug actually is.
I've combed tons of forums and spec pages but there is no clear answer out there. And lots of people are asking.
Will this drive work?
http://www.kingston.com/ukroot/ssd/vplus...
N*
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Mactracker says SATA and but eBay says ZIF *shrug*
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I trust eBay by the way
댓글 달기
It is definitely a SATA drive. The real question is what is the connection interface. Does a ZIF interface exist for SATA drives, or is it a microSATA interface?
N*
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I found a post on iFixit here that answers the question. HDD to SSD
It seems that the A1304 has a SATA drive with a LIF connector.
Now the only problem is where do I find one of those larger than 128Gig?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Correct me if I'm wrong anyone, you must have you have a Mac Book Air rev b since this is the only machine to use SATA-LIF.
The Rev a used PATA, and the Rev C uses standard SATA (or micro SATA. Its not that clear).
Again I could be wrong of course since I am just lately getting into the MAC's.
http://www.macrumors.com/2010/10/27/256g... see if you can find one of these before Apple closes that loop :)
댓글 달기
귀하의 답변을 추가하세요
Neil 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 4,697
