주요 콘텐츠로 건너뛰기
Restricted access changed voice service blocked
Phone was working fine and then it stopped being able to make calls. I was able to use the Wi-Fi network and make texts and then soon after I started getting the message restricted access change voice service blocked I talked to Verizon store and they were unable to diagnose what the problem was
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 달기
답변 11개
가장 유용한 답변
Here is an article on it. In short, its a feature not a bug.
http://valuestuffz.blogspot.com/2016/05/...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I don't what I have done my phone stoped making calls
Update (06/12/2018)
I restarted my phone then when I'm making call it deny
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Method 1: Blocking Phone notification using third party app
Before you do this, check if your Android device has a built-in feature to disable notifications. This feature may be available in Android 5.0 Lollipop and Android 6.0 Marshmallow operating systems, but some systems may not give access to the “phone” app. Go to settings >> sounds and notifications >> Apps >> Scroll down and tap on “Phone” and disable notification. If your phone doesn’t have that feature, it’s time to give some third party apps a try.
If you Android phone is rooted, there is a fix. You can download apps that can block “Restricted access changed” notification.
Download Notification blocker app like this one: Notify Block
Open the app >> You will be asked to grant notification access >> Tap “OK”
Now on the app uncheck “Hide System Apps”
Scroll down and tap on “Phone” (com.android.phone)
Now reboot device and see if the error still persists. Within the notify blocker app, you may find several “Phone” icons. If the above steps didn’t work, try disabling notifications for each of the “Phone” icons on the list.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
can you send me logo of apps
댓글 달기
Method 2: For rooted Devices: Install Notification cleaner app
For this you will need to root your Android and also install Xposed framework. Most rooters will know how to do this.
Install Notify Clean and open it
Scroll down and tap “Phone”
Tap on “Restricted access changed”
Now reboot device and the phone notification will be blocked
Did any of the above method fix this notification error on your Android phone? Do you have any other alternative methods or solution? Drop a comment below.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Blocking the "Notification" is not the solution at all. It's just like ignoring the problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had this issue, and i went to network setting, start searching for network manually after the phone detected the network i selected it and its started connecting i removed the sim card and putted it back in less than a second and i got my phone back to business
Moto z play droid
This is a video i made because i know its a hard time
https://youtu.be/UUL4OJpmkz4
Hello from Dominican republic
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i found a tutorial on this issue check it here https://alltechguru.net/android-restrict...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I just went to settings>SIM manager and there i disabled the SIM and again i enabled it...Then the problem was fixed but after few hours the same problem repeated again... Please help me!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Update (01/02/2019)
Sim card is not from Verizon Wireless
이 답변이 도움이 되었나요?
점수 0
댓글 달기
how r u I'm fine then
kyou
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Body must be at least 20 characters, you entered 11
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Larry Quay 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 41,520
