주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
가스 구동식 및 전기 골프 카트(Club Car Golf Cart 브랜드에 따라 때로는 골프 카(golf car) 또는 클럽 카(club car)라고도 함)에 대한 지원 정보를 제공합니다.
head lights will not work
how to get the head lights to work.i changed the switch but still no lights
Update (02/17/2017)
how to get head lights to work
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 15개
Hi,
What is the make and model number of your Golf Cart?
Have you checked/changed the headlight fuse at all?
의 공유
not sure where the fuse is.there is no inline fuse that i can see
의 공유
hobeck what is the make and model number of your Golf Cart?
의 공유
i have a 2005 club car & i'm not sure where the fuse is to the headligh?
의 공유
I need to know how to fix the headlights on a STAR golf cart
의 공유
댓글 10개 더보기
댓글 달기
답변 3개
선택된 해법
hobeck , check to see if the headlight circuit is fused, possible blown fuse. Check to see if head light switch is getting power with DVOM,(no power either fuse blown, loose plug, break in wire,corrosion,etc.), then check to see if power is coming out of switch, if power coming out of switch, check for power at bulb sockets, no power coming from switch(switch faulty). Power out of switch but no power at socket, break in wire/ bad plug/socket. Power coming from socket check/clean contacts/replace blown bulb. Good luck.
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
raining now but i will try your solutions later. thanks for the help
의 공유
I'd like to know how best to find the fuse. I've found the run/tow 15A fuse, but can't trace out the headlights to find the fuse. It's my father-in-laws 2012 Cruise Car. Headlights stopped working when he put in new batteries recently.
의 공유
I have a 2004 club car it runs but I have no headlights can’t find any fuses any suggestions
의 공유
댓글 달기
Do all four lights need to be plugged in to
I
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Do all four lights need to be plugged in to work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
hobeck 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 65,761
