주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
가정 및 사무실용 HP 레이저 프린터 시리즈입니다. 이 프린터들은 종종 포매터 보드(formatter board) 문제로 어려움을 겪습니다.
Jam light always on
Hi,
Jam light is always on, and i cant print
i have open every single port and tray and there is no sign of paper jam...
i have pressed the test switch, below the formatter card and printed one page with horizontal lines (engine test) ... that means that i have to change the formatter card?
any other way? because it's an old printer and the formatter card is too expensive.
this is where i find out about the test switch: http://www.laserpros.com/tech_tip_p2015....
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Jam sensors are almost always little levers that "block" the paper path, but are easily pushed out of the way, to where the other end of the lever will block some kind of sensor, usually some form of optical beam. sometimes they can be jammed by bits of paper if you remove a jam and a piece tears off.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have seen the levers get knocked out of their sockets when the jammed paper is removed the wrong way. Always pull jammed paper in the direction of the print path to keep from breaking the lever or popping it out of its sockets.
의 공유
댓글 달기
답변을 추가하세요
Chrisostomos 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 29
전체 시간: 6,167
