주요 콘텐츠로 건너뛰기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
208 질문 전체 보기
Blurry texts and screen flickers
Texts are blurry, screen flickers and video/image moves under frozen one.
How to correct it ?
Image and text on the screen use to tremble, up and down, from time to time. When this happens image and text become blurry.
When video is playing,sometimes, one frame freezes, while in the background the video is still playing.
Is it a software related problem or a hardware malfunction ?
(once I hooked the Surface to a monitor, the video played fine,while the problem persisted on the Surface screen)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 11개
Hi,
If it was software it should also affect the external monitor.
It could be a video cable or a tablet screen problem.
How long have you had the tablet?
I have the same problem with my Surface pro 4, which I have had only for about 18 months, the problem started several months ago, and is getting worse. It makes it very hard to do projects! I have searched the Internet to see if there is a way to fix this problem. I love the Surface Pro 4, but unless Microsoft comes up with a solution, I would not buy another of their products like this! Microsoft needs to fix this, as many are experiencing the same issue!1
My surface screen is going blurry, looking like multiple docs are open on top of each other. Can’t read any of it. Screen becomes unresponsive. Does anyone have any advice? Thanks
I am experiencing the same thing on my surface pro!
I just started having this problem. My surface pro 4 is about 17 months old. Happens when the device gets hot.
댓글 6개 더보기
댓글 달기
답변 2개
선택된 답변
Call Microsoft, this is a known issue covered by extended warranty.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
This worked for me. https://www.groovypost.com/howto/fix-fuz...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Emilcar Similien 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 26
전체 시간: 16,892
