주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 3월에 처음 출시된 3세대 HTC One 스마트폰입니다. M8 디자인에서 크게 개선된 점으로는 옥타코어 Snapdragon 810 프로세서와 2000만 화소 후면 카메라가 있습니다.
How to get data from a powerless phone?
3 days ago, my phone was washed for about an hour. My phone will not turn on, but the charging light keeps blinking on and off when I plug it into my computer. I do not know if my battery is dead or the actaully phone broke.
How do I get my apps and pictures from the phone?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
jacob de la rosa , Remove memory card if there is one. Quit charging/powering on device until you have treated for liquid damage as instructed in the guide below(1st link) Techniques for generalized water damage troubleshooting and recovery and 2nd link for dismantling your device to clean of liquid damage/corrosion. This may even get your phone up and running. You may have to consult a data recovery service. Good luck.
Electronics Water Damage
HTC One M9 분해도
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
If you do manage to get the phone running the first thing you should do is remove you data . The Phone likely wont run long
의
댓글 달기
@lpfaff1 Has told you how to restore your phone which is what you need to do to recover your data and apps. There is no other way to recover the info than to repair the phone . Follow L Pfaff s instructions and hope for the best . One last thing , dont put it in rice , this will not help.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Well if you pull the logic board and put it on a new phone it will work but clean the board first and all contacts or take the storage drive off of the board.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
jacob de la rosa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 1,704
