주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dymo LabelManager 160은 빠르고 작고 가벼워서 어디서든 무엇이든 쉽게 라벨을 붙일 수 있습니다. 컴퓨터 스타일의 QWERTY 키보드로 빠르게 입력하고 원터치 빠른 서식 지정 버튼으로 편집하여 매번 완벽하고 전문적인 라벨을 인쇄하세요.
No charge no ink
My dymo keeps flashing low battery sign but I just changed the batteries also I have it plugged into the wall charger I believe this is also causing it to not print probably everything works like it should except there is no writing on the labels once they print out.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
MAGGIE , You could try another compatible charger as it may be faulty. Clean the battery contacts in machine using a pen with an eraser on he end as it is a little abrasive or a Qtip dampened with 90% Isopropyl Alcohol or better, clean the terminals well and then blow out the dust/debri and change the batteries out for some new good quality batteries and try. Good luck.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
In case someone else googles this like I did. I figured it out shortly after. My colleague had inserted a couple of the new batteries the wrong way. Check the direction of the batteries and it should fix this problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had the same problem. I rechecked how I installed the batteries and sure enough 2 of them were put in the wrong way. Corrected this and labels are printing correctly now.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
On mine I have checked the batterys a few times but it still won’t print, the machine is brand new but there is no ink, the baterys are new and good
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
MAGGIE 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 28
전체 시간: 7,343
