주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1418 / Late 2013 / 2.7 및 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
Is it possible to replace the stand?
Is it possible to replace the stand on the 2013 21.5"iMac Ultrathin?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
If you are looking to go with a VESA mount sorry to say Apple doesn't offer the parts. Apple does offer the standard foot as a spare if your's is damaged.
To replace the standard foot will require completely disassembly of the system. This is a very big job! I would recommend you bring your system in to an Apple Store or authorized service center and let them do it as it will be cheaper and less risky.
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
Well, I might have a lead here of a possible VESA mount kit. Just found this: VESA BACKING PLATE FOR IMAC 21.5" (Apple P/N 923-0419)
I found this stand:
http://www.powerbookmedic.com/iMac-215-E...
It seems doable, the complete teardown will be a pain and time consuming though.
That should do it! But again its not something I would recommend if you've never opened one of the Thin series systems. Just the process of taking off the display can damage it which would be a very expensive mistake! Follow this guide: iMac Intel 21.5" EMC 2638 Logic Board Replacement
Here's a user submitted guide which will give you a bit more on whats needed: iMac Intel 27" EMC 2639 Stand Replacement The stand is mounted exactly the same way as yours.
I have opened one before, I work on these on a regular basis, but I've never attempted the stand before.
I appreciate your help!
댓글 달기
No it's never been done but you might be able to find something that you can do such as take out some screws or some clips from the back of the iMac if not there is no way to replace them and if you find a way please post a repair guide so I can help some of my costumers that have asked the same thing.
If this answer helped please give it a thumbs up .
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It is possible to buy a new iMac with a VESA stand: http://www.apple.com/shop/buy-mac/imac-v...
So maybe if you ask apple, they can switch the stand.
As far as I know, that's your best option.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Sorry Apple won't swap the stand. In this case it looks like Amber only wants to replace the damaged foot stand Vs altering it to a VESA.
댓글 달기
답변을 추가하세요
Amber Savoy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 19
전체 시간: 4,185
