주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sharp EL-531X는 Sharp에서 생산하는 공학용 계산기입니다.
How can I fix it?
MY calculator won't turn off except after being left alone for a long period of time and the buttons aren't responding. Also it only displays 0=. and I've even tried restarting it many times.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
The calculator will display 1 no matter with the battery or not.
It stop working.
의 공유
댓글 달기
답변 2개
선택된 해법
Hi,
Try replacing the battery and then resetting the calculator.
The EL-531X uses a LR-44 (or equivalent) battery
Here are two images that show what to do.
Battery Replacement
이미지
Reset
이미지
(click on images to enlarge for better viewing)
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Hi. After changing battery and resetting, all the buttons still didn't work. Please help.
의 공유
댓글 달기
I had the same problem and managed to fix it by removing the battery and unscrewing and removing the back cover. That's it. I reckon that the issue happened because the "=" key connection was stuck, so uncovering the calculator might have "released" the connection. Hope this helps!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
fahimakhan2 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 42
전체 시간: 5,352
