Why does my drone get a Jello-effect?
Why does my drone get a Jello-effect ?
I have tried to utdate everything, but nothing seems to make it better.
Blury picture on the phone while filming..
좋은 질문입니까?
좋은 질문입니까?
That must be from vibration. Most drones that don't have a damper have this problem, but that shouldn't happen with this one. If your under warranty, send it in to DJI so they can have a look at it.
이 답변이 도움이 되었나요?
@pccheese ,Cepeders, Blurry picture on the phone while filming, try a different device as maybe your phone is not linking properly. If under warranty consider using it for replacement/refund/repair. Check to see if the camera/lens is loose on the drone and vibrating around. You may have already done so, do a search( dji mavic pro drone blurry picture) as there is numerous post/articles/forums that discuss this issue. Find below a disassembly guide to get you inside the check for loose wires/components/etc. that could cause an issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 2,055
