주요 콘텐츠로 건너뛰기
The Nissan Xterra is an SUV that was manufactured and marketed by Nissan Motors across two generations, utilizing its Nissan F-Alpha platform shared with the Nissan Frontier pickup.
20 질문 전체 보기
engine noise lower front end. 2006 Xterra
Rattling,like fly wheel bearings.
Thanks,
R.P.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Donna Palmer,engine size/auto or stand. trans.? Is the noise there when engine running and stopped/parked or is noise there when driving only, does noise change when you turn the steering wheel, does the noise speed up or change when you increase the RPM(give it more throttle), is the engine light on?? Check all your fluid levels and anything else you can tell/add recent repairs,etc.
댓글 달기
답변 1개
선택된 해법
D and R investors, Possible issue, info. from link; A whining or buzzing type noise may develop from the timing chain area caused by excess slack in the secondary timing chains. Nissan has issued a service bulletin (NTB09-128) regarding this issue. Replacement of both secondary timing chains and their tensioner shoes will be necessary to repair this concern. As part of this repair, the engine oil and filter should also be replaced. More info. at link below as it seems to be a very common issue.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://repairpal.com/noise-from-the-fron...
https://www.youtube.com/watch?v=zAXbuthJ...
http://www.xterraownersclub.com/forums/u...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
D and R investors 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 2,221
