주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google의 첫 번째 Android 스마트폰인 Pixel XL(모델 번호: G-2PW2100)은 2016년 10월 20일에 출시되었습니다. 5.5인치 AMOLED 디스플레이, 3450mAh 배터리, 32GB 또는 128GB 스토리지 옵션이 있습니다.
WiFi Antenna Replacement Procedure For Google Pixel
after getting the phone wet, I am having issues and facing a WiFi struggle after 3 hours later. it will not connect unless the phone is actually on the router itself. I'm not sure if its because its still wet, or that it actually got damaged completely but i would like to know is there anything i can do to repair this myself, and where the antenna is located and if there is any parts to replace this online or on any stores.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
How did you solve this problem? I have exact same problem on mine. Any help from your side will be really appreciated
의
댓글 달기
답변 1개
가장 유용한 답변
Brandon Tenney, Antenna seems to be a chip soldered to the board(seen in step 11 of the guide below).
If the phone was not treated properly for water/corrosion damage Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. Good luck.
Google Pixel XL 분해도
Electronics Water Damage
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Brandon Tenney 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 32
전체 시간: 7,193
