주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Gateway MS2285는 Gateway의 NV53 시리즈 노트북입니다. 주요 기능으로 AMD 프로세서, 15.6인치 디스플레이, 4 GB RAM이 있습니다.
Computer Screen is black
My computer screen is not working at all. Everything is on while the screen stays black.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
This is mainly caused by a faulty graphics card. Unfortunately this model laptop as with many other models, has what is called an integrated video card. Meaning your Motherboard and Graphics card are one in the same.
What this means is, you must replace the motherboard to replace the graphics card as they are integrated into one another. The good news is, they are REALLY cheap to buy and you can shop around for even lower prices. Just looking on eBay though you can buy one for: $49.99 as of: 4/10/2017 which is much cheaper than other motherboards.
NOTE: This answer is based on the fact you stated your PC powers up, fans come on, but display remains black. There are other causes however this is where you should start as it is the most common reason.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Can't be the Ram failing ?! I have the same problem power on but black screen... You sure it's always the Grafic on this model 2285?
의 공유
@michelecian3692
Connect an external monitor to the laptop and check if you get a display showing on that.
의 공유
Hi @Jayeff
I will try again sooner, give feedback later , thanks👍.
의 공유
댓글 달기
답변을 추가하세요
krystle_kellum 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 27
전체 시간: 2,077
