How to replace wheel?
One of the wheels of the Marathon FC9200 broke off. I bought a new one, but I don't know how to attach it. There is an additional part (red) that is located in the axle, but I don't know if you should put it in the whole and then attch teh wheel, or put it in the axle before attching the wheel to the cleaner. If I try to follow the secon possibility, I feel much resistance and am afraid that I will break either the wheel or the hole into which the wheel should be attached.
좋은 질문입니까?
댓글 3개
You first have to put the round/cylindrical shaped retainer which keeps wheel locked in position into the wheel, and then push the axele into the whole in the vacuum cleaner. It is somewhat scary, as you have to press very hard and I was afraid to destroy the wheel or hole. But it worked!
Jos de Mul 의 공유
Hi all,
I have Philips Marathon Vacuum 9205 . Right wheel came out. Also, there is a red part . I don't know how to keep it inside of the vacuum. hole in the vacum cleaner is wider than the wheel hub. I tried every possibility. but I couldn't do it. wheel is going out. It is like ; there a missing part. I don't know. If you have any idea, please share with me.
You can look at the pictures I took.
https://i.hizliresim.com/V3MpQn.jpg
https://i.hizliresim.com/lbWYQX.jpg
https://i.hizliresim.com/ZOEN5a.jpg
https://i.hizliresim.com/ByAXOg.jpg
Burak Uzel 의 공유
Burak ur links don't work :( and I think u need a NEW wheel ... when the same happend as with mine the 4 hooks that hold the wheel in the Vac are broken off ...
So to replace the wheel i took the hole thing appart...cleaned it ... the wheel comes into the vac from the outside and then u have to push the red part into the wheel from the inside ... push it al the way in till it clicks, then the new wheel should be attached and not fall out...and a little thing to improve when it is open, the knob for the cable retraction has this piece to presses the spring, make that part a bit thicker with some hose or tape around it so it will put more pressure on the cable returner...
lehakok 의 공유
