주요 콘텐츠로 건너뛰기
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
20 질문 전체 보기
Stuck on ok to disconnect
My ipod nano 6th gen was full of songs that i didnt like. it was given to me as a gift but was used. i tried to restore it but everything was gone. i cant put music in it now and its just stuck on 'ok to disconnect' and when i connect it it says dont disconnect. it wont change. what should i do?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 5개
Does iTunes still detect your iPod since it goes to the OK to disconnect screen?
Ya masih mendeteksi
Lalu gimana caranya biar bisa masuk menu
trans. Then how can I be able to enter the menu
If you have a Nano 7 then hold the home button and the volume down together until you see the apple logo
댓글 달기
답변 7개
선택된 해법
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
이 답변이 도움이 되었나요?
점수 15
댓글 9개:
omg omg omg omg thank you sooooooooooo much i was about a second from throwing my ipod mini out
You are absolutely Awesome! Thanks so much.
THANK YOU SOOOOOO MUCH!!!! Omg, I was out running so have no idea what button I was pressing other than I was trying to turn the volume up!!!!! Thank you for this advise, my nano has gone back to the normal screen again now, phew!!!!! :) :) :)
Janet, Sept 2012
Hey my man you a STAR. GOING A VACATION TOMORROW.
THANKS AGAIN.
Hi Guys, how if the volume up and down didn't working, how i can reset the ipod..i've try on itunes..but it's still displaying OK To Disconnect..
댓글 4개 더보기
댓글 달기
I had this very issue and spent six hours on the phone with Apple and they couldn't fix it ...but here is what I discovered and it worked to clear up the issue. First, see if the iPod works on a different computer without automatically going to "OK to Disconnect". If it doesn't, it may have issues. If it does, you need to perform a "Restore" (not a reset) on your 6th Gen Nano. This will wipe out any tunes on the iPod, but you said you don't like the ones on it anyway. Once the Restore is complete, first and foremost, tell it NOT to automatically sync to iTunes on the registration screen that pops up immediately after the restore by unchecking the related box. Then, be sure to Rename the iPod. That's the fix that worked for me, so hope you have the same results. For instructions on how to perform a Restore, go to www.apple.com/support and type in "Restore Nano 6th gen" in the Support page Search box in the upper right corner of the screen. That will bring up instructions on how to do the Restore. Good Luck!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Try holding down the sleep/wake button and the volume down button till the logo appears. Immediately when you see the logo tap (or hold the sleep/wake button my itself) and see if that works...seems to work for me. Good luck
이 답변이 도움이 되었나요?
점수 1
댓글 달기
samueltorrez - You Rock dude!! I was on the verge of giving up and calling it dead till I saw your little note
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My unit worked as it should when connected to computer but was screen stuck on "ok to disconnect" or "do not disconnect" or diagnostic mode. I happened to have another iPod Nano 6th I was working on so I took out the battery/logic board and moved it to the unit with the good flex cable; and it worked flawlessly. Likely, the switches went bad with some water exposure; or there was moisture stuck in there; I replaced cable since I broke the cable trying to expose it. So if reset and restore doesn't work, test the on/off volume, headphone cable. I wrestled with restore/reset for too many hours and searched internet for hours for solution with no luck, then solved it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
None of these are working for me. When I hold down the lower volume and the sleep button it just goes to the diagnostic screen and I can't do anything from there. I have tried restoring it through ITunes and that also did nothing. I don't know how to crack it open and work on it so does anyone know any way that's not listed here.
이 답변이 도움이 되었나요?
점수 0
댓글 6개:
Sorry, I know how frustrating it is. I've been there. You likely need a new flex cable (which will replace the button connections) which wears out too darn quickly on these units. That is only thing that worked for me. Check eBay for a service to send it in to fix. Won't be too expensive, I saw one for $30; 30 min job and $3-4 part if one knows what he/she is doing. Or try to do it yourself. Also, there is a robust market for these units on eBay, even if broken. You can get a working unit for $25-$30 more than a broken one. Lots of fixit people buy the broken ones, fix them, then resell. So don't throw it away if it doesn't work. Sell it as non working unit. Opening these units is not difficult but closing them back up tightly is challenging even if you have the correct adhesive. And there is always a risk of damaging the screens when servicing.
None of the above has worked for me. My little device will not turn off and is stock on 'ok to disconnect' I have connected to power and the device says to Restore on itunes, but every time I try to connect to computer I get this message and now it is permanently on there.
Got a solution guys! not sure if i just crack it or not....but this is how! As usual press the down button simultaneously with he home button, once you see the apple logo, release the down button but still keeping the home button down until you see an option to choose iPod language.
Hope this helps guys!!
It worked!!!!Thanks a million.
Thank you so much nazamania!! It works for me
댓글 1개 더보기
댓글 달기
Help, i tried to restore my ipod on itunes at the end it says factory reset is done and the device will just restart but it never appear so when i plug my ipod again it just performs factory restore again and again help ive been restoring for like 10 times already
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 90
전체 시간: 66,351
