주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2005년 6월에 출시되었으며, 모델 번호 AL1916으로 식별됩니다.
Monitor turns on and off
I read this article Acer AL1916 Troubleshooting
good morning my monitor is powering all right but the moment it comes for a while goes off. It does not blink on and off the monitor is on but the light is deem how can I go about it to make it appear clear and bright?
Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
I had this problem. I opened the display, noted several heinous looking capacitors on the Poewr Supply board, Installed the correct replacements - haven't had a glitch from it in 3 years.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
[http://www.markdigital.com/wp-content/up...
Btw, just because a capacitor isn't bulging or leaking doesn't always mean it's 'Good'.
Hope this helps. It is very important to replace the removed devices with those of equivalent value, especially capacitance. Slightly higher voltage doesn't general make too much difference, never replace the device with a lower voltage specification otherwise it go boom.
Good Luck!
의
댓글 달기
This is most likely an issue with the backlight. Try shining a flashlight on the screen after it goes black, can you still see the display? If so your backlight is going bad and your lcd is fine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
enockgyesi5 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 15
전체 시간: 1,210
