주요 콘텐츠로 건너뛰기
Power Button not responding after screen replacement
Hey guys. I just did a screen replacement, and now my power button doesn't work. if i plug in the device, it shows me it charging on the screen. so the new screen is funtional. I have tried with the old screen, just to verify it wasn't doing something weird with the circuit.
So far, I have tried the following.
- Cleaning the connectors, and reconnecting it.
- Made sure the continuity of the power button exists. (Used a multimeter while pressing the button)
- Reflowed general area of the power button.
im hoping to get a pinout of the power button area, and a place to purchase the female side of the BTB connector. if anyone else has experienced this before, i would like to know how it was rectified. thankyou!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Is it definitely the power button you're pressing? That model has an unusual extra screen on/off button that looks like a power button. The actual power button is on the other side of the phone from the volume buttons.
haha. yes. it is the power button i was pressing. though i did screw that up for a few moments on my first time replacing a screen, that gave me quite a scare. but yes, i am using the button at the top left. i have gotton other Dteks in since this post, and found that i must have broken a resister off of the board when i was lifting the top panel fron the device. I have replaced it, and its working fine. thanks though.
댓글 달기
답변 1개
선택된 답변
I have found a missing component by comparing it to another board. the phone is in perfect working order after replacing the component.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Hi
What was the missing component?
hi Surjit. there are a slew of coils on the board. i seemed to have broken one of them off the board while lifting the top bracket.
Hi, i have this same issue. Do you have picture or diagram that shows what you knocked?
댓글 달기
귀하의 답변을 추가하세요
Scott 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 1,058
